Rotating the 3D view
To rotate the 3D view, either use the Rotate View tool and the mouse, or specify rotation values with the Rotate 3D View command.
When Two-Point Perspective is enabled for a perspective projection (see Projection), it remains active until the view moves too near the top or bottom of the model to maintain two-point perspective without distortion. You cannot roll the view (rotate the view sideways) when Two-Point Perspective is enabled.
Rotating with the mouse
Tool |
Tool set |
Shortcut |
Rotate View
Visualization |
Shift+W |
The Rotate View tool rotates the view clockwise or counter-clockwise in 3D.
To control the movements of the Rotate View tool, drag the mouse or click one of the mode buttons. The first three Tool bar buttons set the center of rotation. The last two modes perform precise, incremental rotation movements in the direction specified.
Mode |
Description |
Rotate Around Object Center
Uses the center of selected objects as the rotation center |
Rotate Around Active Layer Plane Center
Uses the center of the active layer plane as the rotation center |
Rotate Around Working Plane Center
Uses the origin of the current working plane as the rotation center |
Rotate Clockwise/Counter-Clockwise
As an alternative to moving the cursor to set the rotation direction, instantly rotates the view clockwise or counter-clockwise |
To rotate the 3D view:
Click the tool and modes.
Click the drawing and drag while holding the mouse button. Move the cursor to rotate the view in the direction of the cursor movement. Release the mouse button to stop the rotation. Alternatively, use the tool modes to control clockwise/counter-clockwise movement.
Mode |
Mouse movement/key |
Description |
Move left or right |
Rotates about the screen Y axis (or the screen Z axis if the cursor is at the perimeter of the drawing) |
Move up or down |
Rotates about the screen X axis (or the screen Z axis if the cursor is at the perimeter of the drawing) |
Rotate Clockwise |
Each click rotates the view in a clockwise direction about the selected center of rotation |
Rotate Counter-Clockwise |
Each click rotates the view in a counter-clockwise direction about the selected center of rotation |
When the Rotate View tool is in use, the Data bar displays the following information to help orient the view.
Data bar |
Description |
Azimuth |
Displays the active layer plane angle (in degrees) between the positive X axis and the direction from the selected center of rotation to the viewer |
Elevation |
Displays the angle (in degrees) between the selected center of rotation and the plane that is parallel to the active layer plane and passes through the view origin |
Roll |
Displays (in degrees) the amount of rotation about the selected rotation center |
Rotating precisely
Command |
Path |
Rotate 3D View |
View |
The Rotate 3D View command provides a precise way to rotate the 3D view. Enter rotation values directly, or rotate the view in increments. A preview displays the rotation movements before the actual view is rotated.
Select the command.
The Rotate 3D View dialog box opens.
Parameter |
Description |
Parameters are absolute |
Starts the view rotation from a top (absolute) view |
Parameters are relative |
Starts the view rotation from the current view |
Interactive Rotate |
+, - X/Y/Z buttons |
The "+" and "-" buttons for each axis rotate the view by the increment specified |
Angle Increment |
Specifies the rotation increment (in degrees) for the interactive rotation buttons |
Rotate By Value |
Rotation on X/Y/Z |
Specifies the rotation value (in degrees, minutes, and seconds) for the X, Y, and/or Z axes |
